What is this?
lastchancegarage
What is this?
Post by lastchancegarage » Wed Apr 25, 2007 8:14 pm
Can anyone identify this machine by sight? I could not find any data plates or factory markings anywhere. The guy I bought it from said it was a Stowe roller. Anyone have any idea how old this thing is? Engine runs great. I believe it's around 10 hp from the jug size. I know a lot of you guys have been around all sorts of machines. Just hoping someone would be able to recognize what this is on sight.
If nothing else, you can't beat the industrial size cooler on the back. :D
I'll never go thirsty! :wink: 850' of driveway is a long way to crawl on one of these things. Thanks.
1959 JD 440 ICD dozer
195? ATC GT-25 dozer
Post by Lavoy » Wed Apr 25, 2007 9:27 pm
I don't know about the make, but the first problem I see is the cooler is connected incorrectly, there is no line to the operators station.
Post by Tigerhaze » Thu Apr 26, 2007 9:06 am
LOL at Lavoy's comment! :lol:
I looked on the 'net for a Stow roller, and I found a couple of links with pics- they do look like a similar design although the ones I found seem newer than yours. Apparently Stow Construction Equipment has been around for 100 years or so but has been bought out by Multiquip.
http://www.factstechnologylive.com/main ... youtID=107
http://www.stowmfg.com/index.html
Post by NNAATZ » Thu Apr 26, 2007 10:23 am
i think my neigbor has one stuffed in the shed, don't remeber the handier custum cooler thou
i will have to look see somtime, i don't belive it has a briggs on his
lastchancegarage
Post by lastchancegarage » Thu Apr 26, 2007 8:27 pm
Thanks for the replies guys. Lavoy was the first to pick up on the major design gaff! :lol: The way I see it, I'll just leave it there so when the wife sees me rolling along she won't ask why it's there. Of course, after a half dozen trips up and down the driveway she might wonder why I'm in better spirits than when I got started. :) Anyway, I guess this unit is older than I first thought. It's kind of funny in a way, the first unit I looked at was a lot older looking than this one. It's just that when the guy showed up for the sale, he had this one loaded on the trailer and offered me the same price so he wouldn't have to unload it. This one had the bigger motor and a cooler... :idea: , a definite no brainer. It was slipping in forward but has terrific pull going backwards. After taking the cover plate off I was able to figure out how to tighten the forward clutch pack. Now she'll climb a mountain! :wink: Simple mechanical devices for simple minds. Thanks again.
jdzaharia
Post by jdzaharia » Thu May 03, 2007 12:32 pm
Looks like the cooler is rigged up to hold water for the makeshift spray bar(s) above the roller(s). They must have been using it on hot mix asphalt.
Post by Stan Disbrow » Fri May 04, 2007 8:23 am
Yep. That's the problem, all right. It needs to be filled with beer and hooked up to the operator, who, if he drinks that much beer, will be Hot Mixed for sure! :P
Post by NNAATZ » Fri May 04, 2007 10:19 am
i'll help run it :lol: ,yep that will work
