440 ic 3 point
tod
440 ic 3 point
Post by tod » Mon Apr 09, 2007 8:13 pm
lavoy check into it and let me know if your friend still has the 3point imay as well get the best use out of my 440.thanks again the pump works great with the frustrations of taking it off 5 times i finally got to welding the spline shaft solid the coupling was worn out to the pump and i have the other pump that is still good its dis mantled ,if you know anyone that is in desperate need.
jd 440 ic crawler i need parts when i break it.
Post by Lavoy » Mon Apr 09, 2007 8:34 pm
Tod,
I just e-mailed you the info.
Users browsing this forum: No registered users and 207 guests
