lastchancegarage
Post
by lastchancegarage » Sun Apr 08, 2007 9:23 pm
This is the reason the left clutch quit so long ago, the guy replaced the clutch pack but must have used the same pressure plate. The springs were so brittle some of them broke just taking the plate off the assy.
When I took off the floor panels, both brake rods were twisted all out of shape. Add it to the list.
Can the final housings be welded or are they cast? I'm not a true welder, but after looking at the cracks in the right housing, I'm thinking something has to be done.
One more question, does anyone put any sort of RTV sealant around the final bolt pattern to seal out moisture? Thanks.
1959 JD 440 ICD dozer
195? ATC GT-25 dozer
- Site Admin
Post
by Lavoy » Mon Apr 09, 2007 7:44 am
I know I probably preach about it, but the picture of that spring is why I do not reuse pressure plates, it is just not worth it.
The clutch housing is cast iron, it can be welded but I am a little leary of it. Too much stress on a critical part to gamble maybe.
lastchancegarage
Post
by lastchancegarage » Mon Apr 09, 2007 10:19 am
I hear that! Someone wasted a perfectly good clutch pack doing just that. I had a hell of a time getting the steering clutch driveshaft out of the driven disc. Do you also carry the pilot bearing for the steering driveshaft? Just one more part to add to the shopping list. The "boss" is starting to scrutinize my "stuff" a little more these days. Couldn't have anything to do with the fact the oldest boy just got braces.
Hopefully my funding won't be cut before I get the drives back in.
Lavoy - Is there a way to separate the transmission right below the console to gain about 1 1/2" so I can remove the right housing? I really did not want to get into a total dismantling right now. Just curious if others have gotten their housings off without tearing everything down. Thanks.
digitup
Post
by digitup » Mon Apr 09, 2007 9:15 pm
I think I would be looking for an other clutch housing that one has seen better days.Digitup.
- Site Admin
Post
by Lavoy » Tue Apr 10, 2007 7:18 am
IF you split it at the transmission, you will have to pull all of the corresponding bolts out of the other side as well. You might be able to get enough flex in the sideframe to get the housing off.
hunter41mag
Post
by hunter41mag » Tue Apr 10, 2007 3:44 pm
My 440IC manual says to use a thin layer of some type of sealer (shelac) for the final drive housing mating surfaces. I used a loctite product called gasket eliminator and I believe its number 515.
I also had my inner housing off but I pulled the frame rail to do so. Was not that hard but everything needs to be supported properly so it does not shift.
Don
Eastern PA
440IC (1960)
