Reverser
steamfitter99
Reverser
Post by steamfitter99 » Sat Apr 07, 2007 5:21 pm
I would like to know if it is as simple to rebuild the clutch packs of a 440 reverser as the manual makes it sound. Does just the front clutch pack come out by itself or does the differential have to come out as well. I will take pictures of this when I get to it. Thanks, Tom.
Post by Lavoy » Sat Apr 07, 2007 8:43 pm
To rebuild the reverser, the entire center section must be removed from the crawler. The rear clutch pack is held in by a large nut between the reverser and trans.
tod
Post by tod » Sat Apr 07, 2007 10:46 pm
Lavoy wrote:To rebuild the reverser, the entire center section must be removed from the crawler. The rear clutch pack is held in by a large nut between the reverser and trans.
i have a 440 ic and mine dont work either the handle is there but nothing else it would be cool to check this out when you take it apart so i can see how its done and what kinda parts you need.Tod
jd 440 ic crawler i need parts when i break it.
ironyetty
Post by ironyetty » Sun Apr 08, 2007 5:18 am
I've got mine all apart and am working on the spider gears and some bearings, the clutch doesn't seem difficult there is a front and rear clutch pack and as lavoy said a large nut that holds the one side, Wasn't bad tearing it apart, just might get a little pricey if you have to replace all the clutch disks can't imagine there cheap since nothing on John Deere is :lol:
Good Luck let us know how it goes.
Ironyetty
jeff
reverser
Post by jeff » Sun Apr 08, 2007 9:18 am
must be a common problem forward went out on my 440icd wondering how much the clutch packs are and where to get them any info. greatly appreciated thanks jeff.
Post by Stan Disbrow » Mon Apr 09, 2007 8:58 am
Yeah, it's a pretty common problem. The sad part is that it doesn't have to be, since it's usually operator error that causes the problems.
You simply *have* to have the machine stopped dead *before* moving the reverser lever.
The other main source of reverser fault is not keeping the clutch packs adjusted properly.
tod
Re: reverser
Post by tod » Sun May 20, 2007 8:09 pm
jeff wrote:must be a common problem forward went out on my 440icd wondering how much the clutch packs are and where to get them any info. greatly appreciated thanks jeff.
jeff im about to take out my reverser . did anyone tell you where to find the clutches? i dont think theyre available at deere.
Toivo1037
Post by Toivo1037 » Sun May 20, 2007 8:33 pm
tod,
They must still be available, the dealer just re-built my 440 reverser (or so they said they did - see my recent topic)
They charged me for clutch packs, so you should be able to get them.
As far as pulling the reverser, if you have any questions, ask away, I will try to help, I have pulled mine twice now, and headed for #3. The red part on the floor is the lil monster!
-Neil
JD 440 Crawler w/loader
JD 310c TLB
Howard Yoder
Post by Howard Yoder » Mon May 21, 2007 1:37 pm
There is a note in the book about lining the oil hole up with something as I remember. I rebuilt one about 5 yrs. ago and had around a $1000 in parts.
JimAnderson
reverser
Post by JimAnderson » Mon May 21, 2007 6:49 pm
Hope the clutches are still available cause I have two to rebuild.So far
all the bearings could be had from mother Deere.The oil hole in the rear
needle bearing has to line up with the oil hole in the rear hub.You will
know which bearing to install because it is the only one with a hole in
the outer shell.JimAnderson
tod
reverser
Post by tod » Mon May 21, 2007 8:27 pm
Toivo1037 wrote:tod,
-Neil
toivo thanks for the info and the picture.i took mine apart today and it looks like the same mess that your into, hope you get it working properly and get back to your house construction .how did you post the picture? i tried to post pictures on the forum and couldent get them through,i think that is cool that you did that and thanks for the picture.Tod
Toivo1037
Post by Toivo1037 » Mon May 21, 2007 9:11 pm
Tod,
No problem, let us know if you have any questions. That picture will hopefully help someone who thinks that it is too big a job to tackle. Big job yes, but it is very doable. These tractors are not nearly as complex as you averave modern car. Bonus is nothing is metric!
Posting pictures is fairly easy, just look here: http://www.jdcrawlers.com/messageboard/ ... c.php?t=45
[/url]
JD 310c TLB
