jd 440 ic track rollers
tod
Post by tod » Sat Apr 07, 2007 9:13 am
need 2 trak rollers john deere #m2233t . my track fell off and i observed a couple damaged rollers i tried to put the track back on myself and big prybar i need to get it over the front idler and i need to find 2 tarck idlers .will the crawler function for now or will it fall off again?Tod
jd 440 ic crawler i need parts when i break it.
woodchuck
Post by woodchuck » Fri Apr 13, 2007 7:50 am
I checked with my local JD industrial dealer. He can get the rollers you need for $244.52 each. Kind of pricey, but if you plan on using the tractor for some time it may be worth it.
Post by Lavoy » Sat Apr 14, 2007 9:14 am
The ones you get from Deere really will not fit decent, they are huge. I should have a couple of used one, and new aftermarket ones are less than $150.
