1966 JD Crawler 1010 Over heat engine
sergio
Post by sergio » Fri Jun 10, 2005 10:51 am
:shock:
Well I got a nice 1010 Crawler that I was using to do light work BUT....
After runing for a few hours ,,start to over heat and the water/antifreze start to run out near the cap ( on the over flw hole) a lot come out hot. I did not see any oil leak ,
I REFIL THE RADIATOR AND STARTED AGAIN, THE SAME HAPPENED AFTER 10 MINUTES, I SHOT OFF AND WATCH THE WATER GOING OUT .
i HEARD HEAD GASKET, WATER PUMP,,,,,,BLA BLA BLA,,,,,
CAN ANY ONE HELP ME
TY SO MUCH
SERGIO
Howard Yoder
Post by Howard Yoder » Fri Jun 10, 2005 2:00 pm
I would start with the cap and make sure it is good then change the termosat and if that don't help check to make sure the radiator isn't pluged up. Could be your water pump but they usually leak when they go bad. good luck
Users browsing this forum: Bing [Bot] and 11 guests
