JD 50 and 51 backhoe
Post by JD440ICD2006 » Sat Mar 17, 2007 7:17 am
I have seen numerous listings that showed the 50 or 51 backhoe mounted on a 440. It seems to always list a front attachment like a blade or loader bucket. I would like to hang a 50 or 51 on my 440ICD.
Is this a dangerous combination as far as safe operation? If so, why did JD offer and list them together??
Post by Lavoy » Sun Mar 18, 2007 11:44 am
Even with a blade on, you will need to hang counterweight on the front of the tractor to keep the front end on the ground. A local guy had one, and he had hug a couple hundred pounds under the front axle to try and hold it down, and this tractor had a loader on it.
The main reason though is the hoe mount is a part of the loader/dozer frame, so without one or the other, there is nothing to hook the hoe mounts to. Plus, you need the big hyd pump to run the hoe as well.
Users browsing this forum: Google Adsense [Bot] and 218 guests
