420C backfires through carb?
CCWKen
Post by CCWKen » Sun Jun 05, 2005 9:42 pm
Is it normal to have a slight pop from carb? I've done a complete tune and overhauled the carb. The timing is set right but I still get a slight pop from the carb at all speeds. I'm wondering if someone may have set the valves too tight? Any one else seen this problem?
JD420C, Ford 3910, IH 2606, Kenbota G32XKS
JD40c
Post by JD40c » Sun Jun 05, 2005 10:33 pm
My 40C never backfires through the carb, ever. If you're sure the points/condenser and sparkplugs are all good, I'd start looking at the carb.
Post by Lavoy » Mon Jun 06, 2005 12:50 pm
It wouldn't be an all bad idea to check the valves just in case. If one is too tight, you will eventually burn it.
CCWKen
Post by CCWKen » Thu Jul 07, 2005 10:07 pm
Just an update on this condition. I was going to post sooner but got tied up working on other stuf and it slipped my mind.
I adjusted the valves. That helped a little but after running it under working load conditions for a short time, it smothed out. I suspect there may have been some carbon under the exhaust valves. (Rebuilt the carb earlier because of loading up.) After running through a can of top cleaner and re-adjusting the valves, it runs supurb!
Users browsing this forum: original possum and 31 guests
