Stretch
Post
by Stretch » Sun Mar 11, 2007 3:36 pm
I have tried everything I know of, but the steering shaft will not come out. I beleive the shaft is frozen on the hub.
Does anyone know if there might be a keeper somewhere on the shaft? I would appreciate any ideas.
JD 2010C serial number 56507.
Stretch
- Site Admin
Post
by Lavoy » Sun Mar 11, 2007 7:56 pm
Been a while, but I know there is a set screw that comes into play somehow. Double check your service manual.
Stretch
Post
by Stretch » Mon Mar 12, 2007 2:27 am
The manual tells about a lock pin on models prior to 42000. My serial # 56504. I had double checked just in case and cannot see a lock pin.
I think the shaft is rusted on the clutch hub, but short of putting heat to the hub I cannot get this thing to move.
I am trying to do this with out pulling final. I pulled sprocket and final drive pinion as the book said and everything else no problems, but this shaft is a bugger.
Vince
2010OWNER
Post
by 2010OWNER » Tue Mar 13, 2007 1:46 am
Stretch,
It's been several years, but if I remember correctly I just threaded a bolt into the end of the shaft and grabbed it with a pair of Vise-Grips attached to my slide hammer. A few taps and out it comes.
Brian
Users browsing this forum: Google Adsense [Bot] and 232 guests
