Recent 440cid purchase
D2Denny
Post by D2Denny » Mon Mar 05, 2007 7:25 pm
Brough home a pretty decent 440cid with the 2-53 recently. While the weathers cold would like to change out the fluids and filters. anybody have the specs on:
Crancase capacity
Cooling system capacity
trans lube capacity
final drive lube capacity
engine oil fiter number
fuel filter numbers.
Plan on making a trip to TSC to get this stuff in the next several days
Dennis
jac
440ICD
Post by jac » Mon Mar 05, 2007 7:42 pm
Crankcase = 9 quarts
Reverser = 3 1/4 quarts
Transmission = 9 quarts
Hydraulic oil = 7 1/2 gallons if completely empty (w/ 831 loader)
Coolant = 2 1/2 gallons
Finals = 1 3/4 pints
Oil filter NAPA 1100
Fuel filter NAPA 3513
All capacities from Deere manuals. Hope this helps. Check old postings for various discussions on types of oil. There have been a lot of discussion/debate as to what oil to use.
hunter41mag
Post by hunter41mag » Tue Mar 06, 2007 5:04 pm
If you want maximum value for you preventive maintenance efforts make sure to have the components that you are changing the lubricants in up to operating tempature. This will ensure that any contaniments are mixed with the lubricants and will drain out with it. Changing lubricants on a cold component will let the lubricant drain off the contaniments that have settled to the bottom. Than at the next start up the contaniments will mix with the new lubricant. Just my 2 cents.
Don
Eastern PA
440IC (1960)
D2Denny
440CID
Post by D2Denny » Tue Mar 06, 2007 7:52 pm
thanks for the quick response. Off to TSC!!
D2Denny
Users browsing this forum: Google Adsense [Bot] and 231 guests
