My 1010 water pump is on the bench, and I'm struggling to pull off the fan hub / pulley. Have tried with bearing puller, heat, and penetrating oil - not budged yet. I'm worried about damaging where the V-belt rides, and there's not enough space to get behind it - so have been using something screwed into the fan bolt holes.
I only need to replace the seal. Is another option to leave the fan hub on, pull the impeller off, and somehow pull the seal out with the shaft still in-situ?
1010 Water Pump - Pulley / hub removal
1963 (?) Deere 1010 Crawler-Dozer
1955 Ford 850
1973 MF40 Ind
1955 Ford 850
1973 MF40 Ind
Users browsing this forum: No registered users and 60 guests
