Brake pedal moves with clutch 440ICD
DukeofDeere
Post by DukeofDeere » Fri Aug 07, 2026 11:59 am
How do I free up the clutch pedal on the brake shaft?
Re: Brake pedal moves with clutch 440ICD
Post by Lavoy » Sat Aug 08, 2026 12:05 pm
Lots of weasel piss, swearing and praying. Beyond that, split it at the trans so you can get at it better unfortunately.
jimmydiesel
Post by jimmydiesel » Sat Aug 08, 2026 10:32 pm
I used 3 different types of penetrating oil, some cussing, a lot of other ideas and got mine freed up.
It is discribed about 3/4th of the way down on this write up
viewtopic.php?f=1&t=15023
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
Post by Stan Disbrow » Sun Aug 09, 2026 12:04 pm
It can be what I refer to as a Royal PIA. Patience is a virtue here. Soak it with the 50/50 mix of ATF and Acetone then walk away. Next day see if you can budge it. Soak it some more and walk away. Next day.... Yeah. Repeat over and over again. Eventually, you will free it up.
Users browsing this forum: No registered users and 106 guests
