control valve seal kit
Bobby H.
Post by Bobby H. » Tue May 26, 2026 8:16 am
anyone have a idea where I can find a seal kit and or replacement valves for my 450c. Seal kit # is AU40434 or the valve assembly AT43378. Not finding these numbers anywhere online. It's not an emergency just some seepage I wanted to stop.
Re: control valve seal kit
Post by Jim B » Tue May 26, 2026 10:47 am
It looks like the AU40434 kit is available from John Deere. It also looks like it will only do one valve section. The other thing it to use the part catalog and figure out which parts you need and order them individually.
I did get some hits with an online search using the AU40434 part number. One would need to do some emailing or phone calling to see what is actually available.
Bobby H.
Post by Bobby H. » Tue May 26, 2026 6:24 pm
I checked with RDO Equipment but they said NA. I check with JD and see if they have Thanks Jim. She is finally up and running but has a slight seep. one gallon per year or two kind of seep. not Real concerned but would like it right. :shock: :D
Post by Jim B » Wed May 27, 2026 4:41 am
RDO is a JD dealer they should know. Did you ask them to do a system search? I have seen JD show things in a manner that would indicate they were available and sometimes they are not.
You may need to order what you need as individual pieces. Having to do that is a common thing when kits are no longer available.
Users browsing this forum: No registered users and 74 guests
