John deere 350 4 cylinder
Hello all. I am looking at a JD 350 4 cylinder and am considering bye this unit to repair resell or possibly keep. From what i know the 4-cylinder I 'sent very common. Are parts available for the most part anything i should look out for? It has stuck clutch (i have delt with this before and appears to have dozer loader pads on track or very worn slandered dozer pads. Asking 3500. Looking for any input.
Re: John deere 350 4 cylinder
Are you sure this is a 350? Because I have never seen or heard of one with a 4 cylinder engine.
There are many things I haven't seen or heard of however I'm with Leonard on this. I haven't heard of a 4 cylinder 350 or seen one. Two things come to mind. First is it might be a 1010 with 350 decals. The second is someone assembled it themselves.
Study it carefully, look for serial number tags on the motor and sheet metal. You already have a 350 and should know where the serial number tag is supposed to be. The 1010 diesel will have a vertically mounted injection pump on the right side of the engine.
Pictures would be great to see.
Maybe it is actually a 450....
