JD 550 3325 Winch Control Cable Blocks
redneckracin
Can anyone share a picture or description of where the control cable blocks get mounted? I have the bolt for one set up closer to the control lever, but the parts diagram and the service manual don't really show the second location. Thanks!
Re: JD 550 3325 Winch Control Cable Blocks
The clamps go on the fixed metal ends of the cable jacket. On a 450E the one on the handle end is about 8 to 10 inches below the handle in a hole in the side panel under the seat, it sounds like you are set on this one. The one on the winch valve end is mounted on a bracket towards the center of the winch from the valve, that bracket is shown in the 550 parts catalog, so I believe the mounting points are very similar if not the same.
redneckracin
I don't know why when I was looking at the diagram, I saw the two sides of the same clamp and thought it was two separate clamps. Oh well, I broke one of them so I ordered the 4 replacements....
https://shop.deere.com/us/diagrams?deal ... ry=03015-1
