Reverser to clutch swap
jafunk
Post by jafunk » Fri Aug 29, 2025 1:49 am
Has anyone swap from a reverser to a stanard clutch if so what all has to be changed. The track bolts are broke and some holes have been redrilled and tapped but unknown size. Thanks
LeonardL
Re: Reverser to clutch swap
Post by LeonardL » Fri Aug 29, 2025 8:26 am
It can be done but would be expensive and would depend on parts availability. Basically you have to replace the flywheel on the engine to accommodate a pressure plate and clutch disc. Then a drive shaft to extend from the clutch to the transmission. Then you have to replace the entire center housing that has the throwout bearing and clutch release mechanism to replace the reverser.
Post by Jim B » Fri Aug 29, 2025 6:04 pm
To go with Leonard's info here is a direct link to the 350 Parts Catalog so you can see all the parts to change.
https://partscatalog.deere.com/jdrc/nav ... ment/17063
Users browsing this forum: Struckzb86 and 18 guests
