450 Quill Question
450FiveString
450 Quill Question
Post by 450FiveString » Wed Aug 20, 2025 9:00 pm
Image http://jdcrawlers.lcent.com:8000/johnde ... 0897~4.JPG
This is the quill out of my straight 450 from behind the steering clutch. Does any body know what this plate is? It's about 1-1/2 x 2 x 1/16" thick and it's bolted and safety wired in place. It's not in the parts manual and I can't figure out it's purpose
450FiveString
Re: 450 Quill Question
Post by 450FiveString » Wed Aug 20, 2025 9:04 pm
Well I see my pic didn't show up. I tried for an hour to get it but obviously did something wrong :(
Post by Jim B » Thu Aug 21, 2025 6:33 am
I see you pictures when I look on the picture server. I don't have an answer for that plate.
Just to review how I attach a picture.
Log into the picture server. Find my picture I want and click on "Edit file information".
Copy the url ending at the 10023/
Go back to my post and click on the picture icon. Insert the copied url between the brackets of the img markers.
Go back to the picture server and copy the picture title in the box after the url.
Go back to the post and paste the picture title at the end of the url you pasted before. Make sure the / is still after the 10023 and that there are no spaces ahead of or after the picture title
Hope this helps
450FiveString
Post by 450FiveString » Thu Aug 21, 2025 11:17 am
Cannot log in to the picture server. Instructions don't show up in FAQ's. What's up?
Post by Jim B » Thu Aug 21, 2025 4:57 pm
It would seem you must have logged in to the picture server to put pictures there. And the URL in your first post of the thread looks like you were on that server. Did you set up a username and password for that server with Lavoy?
Below is picture I see on the picture server, multiple times dated yesterday, I think is yours (username for the gallery this picture is in is bill).
lsgadd
Post by lsgadd » Sat Aug 23, 2025 9:49 am
It holds the oil line in the Pinion Shaft
In Parts Manual PC922 under
35 Transmission, Differential And Clutch Housing /
SPEED CHANGE GEARS AND SHAFTS (CONSTANT MESH TRANSMISSION) [01G08] - 35-16B
37 -PINION SHAFT Part# AT59731 there's an oil line in the rear of the Pinion shaft.
parts break down of oil line and strap in manual
Transmission Oil Lines (HI-LO-Reverse Transmission) [01G20] - 35-28
8 -OIL LINE Part # AT30739
9 -STRAP Part # T20917
JD 410 Backhoe
2-JD450 Loader
JD 450B Loader
JD 450C Loader
Cat 931B Traxcavtor
Cat 951C Traxcavtor
New Holland 5030 4X4
1964 Ford 4000
Users browsing this forum: No registered users and 190 guests
