450c John Deere crawler
Hmorr
Post by Hmorr » Thu Aug 07, 2025 10:06 am
For some reason the fill plug on steering clutch housing on both sides is over filling and I know I have never over filled it. Does anyone know what else could cause it to overfill?
Re: 450c John Deere crawler
Post by Jim B » Thu Aug 07, 2025 11:12 am
450C should have the common sump. The steering clutch housing plugs are commonly installed with Loctite to prevent opening them. The common sump level is a bit higher than the level used when they kept the compartments separate. Check and fill location for those compartments is the transmission. During a full service they can be removed, fill to the plug level, install the plugs and check/top off the transmission. Check several times a while apart to let the levels equalize.
There should be info in your Operator's and technical manuals about this.
