Spring run
Spring run
Decided to try starting the 420. Not quite enough battery to get it going. Got out the extension cord and charger. About 30 minutes and it fired right up. Last fall i changed oil in everything except hydraulics. This was the first run on it. I took it up the hill to push some mud that didn't need moving but the 420 needed some charging time and to wear off any rust starting to form on clutch plates. A good time was had by all!!
