Hydraulic Adjuster, 1010c - salvageable?
reedgmi
Post by reedgmi » Sat Mar 22, 2025 3:35 pm
Trying to figure out if this adjuster can be salvaged with new seals? Are there any specs for bore / rod diameter?
There's a taper wear to the bore, from ~2.36" at the bottom, to 2.42" at the top.
The bottom is relatively clean, the top is corroded and pitted
The piston rod is 2.31 to 2.34"
When the rod is pulled out lets say 2" from the bottom, it has some side to side wiggle - as expected with that taper wear.
What do you guys think?
1963 (?) Deere 1010 Crawler-Dozer
1955 Ford 850
1973 MF40 Ind
Re: Hydraulic Adjuster, 1010c - salvageable?
Post by Lavoy » Mon Mar 24, 2025 8:08 am
Hone the bore, put on a new cup and it will in all likelyhood be fine. The rawhide cups are quite forgiving.
reedgmi
Post by reedgmi » Mon Mar 24, 2025 8:48 am
Cool!
Flex hone is OK, or with rigid stones?
1955 Ford 850
1973 MF40 Ind
Post by Lavoy » Mon Mar 24, 2025 10:14 am
I usually use a rigid, but I don't have a flex hone that small.
Users browsing this forum: No registered users and 75 guests
