JD 350B 6310 bulldozer
My 1973 JD 350 B 6310 bulldozer comes with the manual adjusted blade. I have found an online sale for a 1966 6-way blade frame and hydralic cylinders that I think was off a 6305. just looking at pictures it looks like it is not an easy swap, if at all possible. I have also reviewed my Technical manual and I am not optimistic. Thoughts or comments.
Re: JD 350B 6310 bulldozer
In order for you to swap this over you will need the entire set up. You will need the hydraulic lines and a control valve for the six way. It can be done but is a lot of labor. Much better system but you will just have to decide how much you would benefit from the change over. You can go to (https://partscatalog.deere.com/jdrc/ ) Look up your machine and the blade to see what all you will need to use as far as parts.
Thanks, I have talked myself out of it.
