Clutch pedal bushing 350
DustinM
Post by DustinM » Mon Mar 03, 2025 5:49 am
I have a 350 with reverser. The clutch pedal has a lot of slop. How do I get the pedal out to change the bushing?
Re: Clutch pedal bushing 350
Post by Jim B » Mon Mar 03, 2025 2:33 pm
There is a snap ring and washer that hold the pedal on the pin(shaft). You actually can unbolt the pedal from the arm that has the bushing in it. If there is not enough room to slide the arm off the pin, it would appear you would need to pull the engine to get the bell (clutch) housing out of the frame and then remove the arm. Your service manual might give you some info.
DustinM
Post by DustinM » Mon Mar 03, 2025 2:41 pm
There is only 1/2” clearance between the clutch pedal and the frame. I was hoping I wouldn’t have to pull the engine.
LeonardL
Post by LeonardL » Tue Mar 04, 2025 9:45 am
The only way to remove the pedal is to pull the reverser. So unfortunately it is deep. Pull the motor and then pull your reverser.
