What do these 2 handles on each side on the upper radiator support do? Other than get in the way of taking on & off the aftermarket grill guard? I would have removed them, but they seem to be quite rusted in there, even after removing the set screw things on the side.
https://photos.app.goo.gl/PrqtxUYhvFE1FiPT6
https://photos.app.goo.gl/mLi3VcHHpU49CMcD6
https://photos.app.goo.gl/WjBcNobTLucvf9B87
It was quite annoying to have to disassemble the whole front of the machine to replace a blown hydraulic hose coming off the pump. I just finished resealing the cylinders & replacing all the hoses between the valves & cylinders. So of course one of the 3 hoses I didn't replace blew while plowing snow the other week.
As I'm only using it as a backup machine for plowing snow & playing forklift when my new HST tractor isn't around I'm tempted to leave the grill guard off. Show off the original JD grill & less effort to reinstall. Any thoughts?
Found a wet spot with a hint of green at the bottom of the radiator when I was in there as well. Coolant is only 2" down, so not to bad, but not good. The leaky valve cover gasket I found is less concerning. At least all the hydraulics are back together & aren't leaking anymore.
What are these handles under the hood up front for?
1956 JD 420c crawler loader
2016 Kubota L4060hstc
- Canuck 420c
- Contact:
Re: What are these handles under the hood up front for?
Those look like the light arms that hold the headlights in place
Nothing Crawls Like a Deere
Headlight brackets, can't use them on loaders, take them off.
