JD 550 oil cooler issues
TOLEWIS
Post by TOLEWIS » Wed Nov 06, 2024 5:45 am
I have a issue where coolant is getting into my transmission. I was wondering if anyone had installed a aftermarket cooler for the transmission and just bypassed the radiator. I was thinking of just adding a piece of hose to connect the two cooler lines coming out of radiator. That should contain any leakage from the radiator. Just trying to figure out a solution with out pulling radiator. I'm reading its a struggle to those repaired.
redneckracin
Re: JD 550 oil cooler issues
Post by redneckracin » Sat Jan 17, 2026 3:30 pm
Someone has bypassed my cooler by putting pipe plugs in the radiator and looping the cooler lines together. I'm trying to find either an aftermarket tank or a stand alone radiator!
