jd 350 c rear axel bolt threads
Jamie Dunn
Post by Jamie Dunn » Tue Sep 17, 2024 8:08 pm
The rear drive sprocet came loosewith 3-bolts sheared off and others with bad threads. I have re-tapped but the holes are too far gone. I either get a new axel and replace it or drill bigger and re-tap. Any other ideas out there?
original possum
Re: jd 350 c rear axel bolt threads
Post by original possum » Wed Sep 18, 2024 9:11 am
I have seen a single bolt replaced by a dowel. Is there room for a bolt with specially shaped manually ground) nut?
Users browsing this forum: No registered users and 49 guests
