Identify year of production for a JD 350C dozer
DarylDeGroff
Post by DarylDeGroff » Sat Aug 31, 2024 8:36 pm
I recently purchased a JD 350C and can’t identify the year and locate pictures of what it should look like for the remake. The serial number is 350CE-224755T. Any help would be appreciated, thank you
Re: Identify year of production for a JD 350C dozer
Post by Jim B » Mon Sep 02, 2024 3:33 pm
Welcome to the Boards.
On the housekeeping side of things posts about your 350C should be on the Late Models Board. This board is for questions and announcements related to the site, not crawler questions. A Moderator will likely move it over there when it is seen.
224755 is a 1975 serial number. The first thread on the John Deere crawler FAQ's Board is about the serial numbers for the 350 models.
350C is the model/series.
E stands for diesel with inside dozer blade
224715 is the unit serial number
T stands for it was built at the Dubuque Tractor Works plant.
Users browsing this forum: No registered users and 52 guests
