Installing a 2010 diesel into a 1010 diesel crawler
bgiese
Post by bgiese » Mon Jul 29, 2024 7:56 pm
Hi
have a 1010 dozer with a bad engine, just picked up a 2010 engine looking to install it into the 1010 frame first glance the air cleaner is
bolted to the side of the engine rearward of the injection pump on the 1010. the fuel system is a tad different with the 1010 having a sediment bulb before the filters and the 2010 has a sediment bulb under the first filter and the crank mounted hydraulic pump has a smaller crankshaft belt pully on the 1010 the belt pully/crankshaft pully on the 2010 is considerably larger
could I use the crankshaft pully from the 1010 on the crankshaft of the 2010 engine
will the mounting bracket for the air cleaner from the 1010 engine bolt to the 2010 engine
thanks for any advise
