1949 MC in excellent condition but no blade
JDMarty
Post by JDMarty » Wed Jul 24, 2024 8:05 pm
I purchased a 1949 MC a few months ago that never had a blade. I've purchased parts and installed to make it run like new and it does run great. It was used without a blade by a pastor to help stuck parishioners when stuck (I was told). I did find some hydraulic cylinders that mount inside the tracks and the arms and blade. I also found an MT pump. I need help with the lift cylinders because they need rebuilding before I would try to figure out how to put this all together. FYI I also own a 1951 MT which I totally rebuilt 25 years ago and use it on my farm to this day. The MC was a barn find and the undercarriage is near perfect ,except for some surface rust. I think it is worth mounting this blade on. Do you sell rebuild kits for these cylinders?
Are there any clues as to how to/not to proceed mounting a front blade?
1949 JD MC
1951 JD MT
1951 Ford 8N
2025 JD 5075E
Re: 1949 MC in excellent condition but no blade
Post by Lavoy » Thu Jul 25, 2024 7:50 am
We would need a lot more information, what blade, what cylinders, etc to formulate a good answer.
JDMarty
Post by JDMarty » Thu Jul 25, 2024 10:10 am
I guessed I was supplying way too little info about what I have. I will go out later and attempt to extract some casting numbers, etc. I'm happy to see that this website is very much alive.
1949 JD MC
1951 JD MT
1951 Ford 8N
2025 JD 5075E
JDMarty
Post by JDMarty » Thu Jul 25, 2024 6:41 pm
The slave cylinders say N111Y JD and N112Y JD. The lift arms are 60" long and have a square crossbeam attached to the end of them. This appears to have features that mate with opposing ones on the blade. The blade itself is quite heavy and is 73" across by 20 " high. It looks like this is the system that mounts outside the tracks. There are two steel pipes each with hydraulic lines on each end. There are also a myriad of brackets, bolts, spacers, and arms. Does this sound familiar? While not new to old tractors, I am certainly green when it comes to JD crawlers.
1949 JD MC
1951 JD MT
1951 Ford 8N
2025 JD 5075E
dtoots1
Post by dtoots1 » Fri Jul 26, 2024 7:48 am
Add location to your profile..tgat is in dropdown login box....someone may be nearby to take a look see.
JDMarty
Post by JDMarty » Fri Jul 26, 2024 9:45 am
Done. I'm in Aurora, Oregon but it's now in my profile.
1949 JD MC
1951 JD MT
1951 Ford 8N
2025 JD 5075E
Post by Jim B » Fri Jul 26, 2024 5:04 pm
Your description could fit many dozer blades. The cylinders could have been used on several. Pictures will help. You need to use a third-party hosting site to post them, like Imugr, or Postimages.
JDMarty
Post by JDMarty » Sat Jul 27, 2024 3:36 pm
Thank you! I'll go see how to drive the image posting sites you suggest. I noticed the image posting icon barked back URL.
1949 JD MC
1951 JD MT
1951 Ford 8N
2025 JD 5075E
Post by Stan Disbrow » Sun Jul 28, 2024 7:20 am
We do have a photo server associated with the group.
http://www.jdcrawlers.com/messageboard/ ... =5&t=13015
The board can host images, but it is really easy for some Spam-O-Bot to take advantage of and so it was disabled. Hence the off-site storage and linkage requirement.
dtoots1
Post by dtoots1 » Sun Jul 28, 2024 10:11 am
JDMarty and Stan,
Our "dedicated Pic Server" is actually up and running....
In order to LogIn to the pic server...you must register your name and password direct with Lavoy at postmaster@jdcrawler.com
Instructions can be printed directly from the message board forum..;and the hyperlink to access in that message..at bottom of page after having logged in the the crawler message board...just follow each instruction exactly as spelled out...
Any questions or problems send me a pm and will get back to you....with my cell number
Dtoots1
Post by Stan Disbrow » Mon Jul 29, 2024 6:13 am
Once you get signed up, you can see how I used it in this thread:
http://www.jdcrawlers.com/messageboard/ ... =2&t=13107
The subject there has zero to do with an MC but you can see how pics are embedded into your thread by looking at the page code in your browser.
JDMarty
Post by JDMarty » Mon Jul 29, 2024 9:18 am
I will try posting pics after I get privs from Lavoy. Went to Steam-Up in Brooks Oregon this weekend and found several JD crawlers there. What an awesome event for old tractor/crawler buffs! One actually had my exact blade and mounting. It was a 1051 MC. The very friendly owner told me his was a Holt made in Independence Oregon, now out of business. I got good pics of the mounting and some clues. I am still back to rebuilding my extremely-heavy-hydraulic-cylinders before attempting installation. They do mount inside the tracks and, given their heft, certainly add low level ballast.
1949 JD MC
1951 JD MT
1951 Ford 8N
2025 JD 5075E
JDMarty
Post by JDMarty » Mon Jul 29, 2024 9:21 am
sorry! my last post had an error. the crawler I saw was a 1951 MC.
1949 JD MC
1951 JD MT
1951 Ford 8N
2025 JD 5075E
Post by Stan Disbrow » Tue Jul 30, 2024 7:16 am
Wow! A crawler from 1051! That'd win the Oldest Crawler Award!
I did process a Next Door Key On The Keyboard routine when I read that. :)
JDMarty
Post by JDMarty » Tue Jul 30, 2024 11:08 am
I have put an image of my blade mounted on a 1951 that I saw at the Oregon SteamUp.
https://ibb.co/hHgShTS
Can anyone identify it?
1949 JD MC
1951 JD MT
1951 Ford 8N
2025 JD 5075E
Users browsing this forum: No registered users and 85 guests
