jd 350c winch problems
silverrex4
Post by silverrex4 » Thu Jul 18, 2024 4:12 pm
Hey all, had to replace my winch cable after the old one broke after it stalled the dozer in reel mode. After I replaced now it won't reel in. I get free spool and lock, just hoping I didn't break something. Hoping it's an adjustment. Let me know what you guys think. Thankyou much.
Re: jd 350c winch problems
Post by Jim B » Thu Jul 18, 2024 6:13 pm
Which model winch? 3315 as was originally used? About the only adjustment in those is the brake band. The wind in is a hydraulic clutch pack. The winch has its own hydraulic system. You might have a control valve problem. Do you have the 350C Technical Manual TM? It will have info on the 3315 winch.
silverrex4
Post by silverrex4 » Fri Jul 19, 2024 5:55 am
I have to dig it up. I think I had it on the computer. I will check it out. I think u can be right cause the free spool and brake works. Could be valve issue. Keep ya posted.
Users browsing this forum: No registered users and 37 guests
