My JD40C has 420C hydraulics on it. I'm planning on going through the valve stack and have the part numbers for everything but the seal that goes in the brass nut that fastens to the reservoir itself. It honestly looks like a piece of hose but figured JD was a little more creative than that.
I have the parts list but cannot find the tube that is held into the valve base with a snap ring on any of the exploded views.
Any help would be appreciated.
Seal PN for nut to reservoir - 420C
1955 JD40C with 420C hydraulics and 6' Leeman-Hass blade
1965 JD 1010 RS High Cropper
Re: Seal PN for nut to reservoir - 420C
Give Lavoy a call, he likely has them. 701-361-1006 during CST business hours.
Just went through this as I am stacking a 4 spool valve for my 420C. JD part number is M1167T and is no longer available according to my dealer. Mine is in good shape but seems you could make one easy enough.
Cubby267
1956 420C #80122
Cub Cadet collector;
100, 102, 104, 147 & 1200
1956 420C #80122
