Seperating tracks without a track press 450E
drssink
Post by drssink » Thu Mar 28, 2024 8:56 am
I don't have a track seperator press (most of us don't) so in looking around for easiest way to do it found a "youtube channel" which shows how to do it literally in about 10 minutes setup to having master pin completley out of chain. "FarmCraft101" watch entire video,his first attempt is a pain. half way through video he figured it out and it works! By accident found an ancient crowbar while brush hogging cut it off like he did, used for driving pin. course you can use whatever fits that won't bend/deform with 16lb sledge. Heat is the key,actually not a lot of sledge swinging once chain is heated up. Reverse procedure to get master pin back in. :D
