450 dozer transmission oil pump dowel pin T20902
MyJD450
Post by MyJD450 » Mon Mar 11, 2024 1:31 pm
Does anyone know the specs of part T20902 for a JD 450 dozer transmission pump dowel pin, or a source to purchase?
Thank you
Re: 450 dozer transmission oil pump dowel pin T20902
Post by Jim B » Mon Mar 11, 2024 3:21 pm
A search using the part number on the JD parts site shows that is the only place that dowel pin was used. Finding a salvage yard with a transmission parted out is likely about your best chance. Send Lavoy an email or give him a call he might have a suggestion of someone to check with. What is your general location, that might jog someone's memory of a place near you.
I know it is a long shot, but have you asked your dealer if they could possibly get the dimensions? How about measuring the hole diameter and depth in both parts and having one made? McMaster Carr might have something if you have dimensions? Find one the right diameter, you can always shorten one that is too long.
