Looking at a parts tractor, 430c. Mine is a 420C.
1. It has a 3pt. Does that fit on my 420c or are the mounts different?
2. Chains and pads look a heck of a lot better than mine. Are they the same? My chains are fine, but my pads only have a hint of the grousers left.
3. Finals the same? My right side cover has a chunk out of it, and while not in a bad place, it bothers me.
TIA.
compatibility between 420c and 430c
Re: compatibility between 420c and 430c
Lavoy and others will likely be along with more info, but as far as i know a number of parts can be swapped back and forth between them. You can use the online parts catalog to compare specific parts if you want. Below is a link to PC05 which has both in it, in case you don't have a parts catalog.
420 and 430 Parts Catalog PC505
Users browsing this forum: No registered users and 67 guests
