420C Single Remote Control Valve Assembly
miramar154
Post by miramar154 » Mon Jan 15, 2024 8:15 am
The oil return tube on my Single Remote Control Valve (this is the tube that returns oil back to the reservoir). Leaks oil profusely when the crawler is running. I have replaced the seals in the valve assembly and the seal on the oil return tube but it still leaks. What is the order for installing this seal? Maybe I have installed incorrectly? Thanks in advance.
Re: 420C Single Remote Control Valve Assembly
Post by Jim B » Fri Jan 19, 2024 6:48 pm
This may help. This link will take you to the parts catalog and I think I have the right page open for your lines. You can use the arrows at the top of the page to scroll to other pages. Are the seals you got the right part number?
https://partscatalog.deere.com/jdrc/sid ... pgId/94359
Post by Lavoy » Mon Jan 22, 2024 3:10 pm
Seal goes betwen the flange on the tube and casting. If I remember correctly it is just an oring.
