on the left side steering clutches..
the brake lever riding on the steering shaft. i see that is uses a snap rings to hold it in place i have removed it. but still cant get the brake lever to slide off shaft.. i know the steering arm has a woodruf key and set screw.
should'nt the brake lever slide off or is there something i am missing...
350 b brake lever
350 b brake lever
74 350 B dozer 6 w/blade.
Re: 350 b brake lever
Yes, the lever should come off once you have removed or loosened the set screw. I usually just remove the screw completely. The lever could be seized with rust, If you have a torch then some heat can be applied to help loosen it. I have also used a good penetrating oil and then drive them off with a hammer. Just be careful not to break the lever.
i got it off heat and air hammer now working on the clutch lever slow going for sure,,
