400G Owners
400G Owners
I am needing the measurements and thickness for the rear belly pan brackets that bolt to the final drives and the bar that goes across. Also the length of the spacers too. Any help on this or where I can purchase at a scape yard is greatly appreciated.
Re: 400G Owners
It would be best if you start by making a list of the parts you are looking for from the parts catalog, by parts catalog name, part number, and quantity required. Here is a link to the 400G Parts Catalog (PC2209) open to the drawbar page, which shows the parts you are looking for, I think. They are not included in the belly pan drawings. Some of these parts may be used on other machines, hence the suggestion you use the part number as well as the parts catalog name.
https://partscatalog.deere.com/jdrc/sid ... pgId/67353
Here are some links to some places you could check, along with your JD Construction equipment dealer.
http://pbhequipment.com/ P. B. & H. Equipment, Antrim, NH
http://www.macfaddens.net/ MacFadden & Sons, Inc., Sharon Springs, NY
https://450johndeereparts.com/ Hudon's, Barneveld, NY
Wenger's of Myerstown, PA
All States Ag Parts (They have multiple yards around the US)
You will likely need to pick up your phone and call these places. Most salvage yards don't list everything, if anything, they may have or can find; online for people to just browse and order.
