440 tractor hyd filter
smitty906
Post by smitty906 » Sat Dec 09, 2023 3:37 pm
Need help to cross reference JD U10280U hydraulic filter , for a model 71 loader .
Tried napa no luck
Re: 440 tractor hyd filter
Post by Jim B » Sat Dec 09, 2023 5:01 pm
Is that a replaceable filter element or is it a cleanable screen/mesh?
smitty906
Post by smitty906 » Sat Dec 09, 2023 7:45 pm
It is a cartridge type that looks like cork or gasket material for lack of better description.
Falling apart like a slinky .
Post by Jim B » Sun Dec 10, 2023 11:50 am
You could join Yesterday's Tractors Forums and ask about this filter on their John Deere Forum. They have more wheel tractor-oriented folks there. One of them might have or be familiar with that loader and have a cross for the U10280 filter. John Deere dropped most of the letter suffixes years ago so U10280 is the current part number. When I check my dealer's inventory it shows as available to order at $101.35. Whether or not JD actually has any available would require getting your dealer to check.
smitty906
Post by smitty906 » Sun Dec 10, 2023 6:34 pm
Thanks Jim
I will check with the dealer tomorrow , I knew they would be pretty proud of their filter .
Was hoping I could cross reference ....but no dice .
smitty906
Post by smitty906 » Mon Dec 11, 2023 10:56 am
Per John Deere ....obsolete
Huh
Post by Jim B » Mon Dec 11, 2023 11:52 am
Did the dealer do a system search to see if any other dealer might have a NOS one setting on the shelf? Beyond that you will have to see what you can mount in the suction line to the pump or in the return line from the valve to the reservoir. If you can get some measurements from the remains of the old one you might find a mesh screen element to adapt in place of the original element.
smitty906
Post by smitty906 » Mon Dec 11, 2023 5:38 pm
I may try to find a canister to replace , and also look at remote adaptor with screw on filter.
