I am trying to get the fuel gauge working on my 1010. I think there should be a ground from the sending unit to the tractor frame, but mine is missing. Can anyone send a picture of how the ground was originally installed?
Thanks.
1010 fuel gauge ground
Re: 1010 fuel gauge ground
I don't think there was a ground wire and none show as part of the harness in the parts catalog. If you want to add a ground just use one of the sending unit's mounting screws to put one end of a wire under and run the other end to a frame location of your choosing.
Thanks for the reply.
The reason I asked about the ground was I can’t figure out how the sending unit will work without a ground connection since the tank seems to be isolated from the tractor frame by the rubber tank mounts.
Any thoughts on that?
Steel fuel lines and fittings form a ground.
I hadn’t thought of that!
Thanks.
Thanks.
Users browsing this forum: No registered users and 81 guests
