Grease in Rockshaft
420C-Mike
Grease in Rockshaft
Post by 420C-Mike » Tue Oct 24, 2023 8:11 pm
My rockshaft seals leak and won't hold oil. Can I put a grease zerk in the fill or drain hole and use grease like I do on the rollers?
gus
Re: Grease in Rockshaft
Post by gus » Wed Oct 25, 2023 5:15 pm
No idea about a factory rock shaft. On my home made 3 pt using a tractor shaft, I drilled and tapped several spots and use grease.
Could you use the light grease, corn head, like the rollers are supposed to use? Kind of in-between oil and grease.
Post by Lavoy » Fri Oct 27, 2023 4:24 pm
I can't see it hurting anything, but better make sure it is full, and coming out past the seals or you won't have any grease around the shaft.
