Carco C12 winch.
- jimmydiesel
Carco C12 winch.
Well another 440ICD followed me home last week, it has engine trouble so I don’t have it running yet. The dozer has a Carco C12 winch that the previous owner says doesn’t work. I have found a lot of references to the C12 on Case dozers but none on John Deere 440’s. Does anyone here have any experience with a Carco C12. When I do get the engine running I hope to be able to get the winch working also. I ordered a parts manual for a Case C12. I haven’t found a repair manual. Haven’t seen much for parts availability ether.
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
440 ICD 831 Loader
440IC 831 Loader
Re: Carco C12 winch.
You may already have this info. Carco is part of the Paccar Winch group. They have some literature for download on their site in the service area I believe. For an older winch you could try contacting them as they might have something just not on the web for viewing.
https://www.paccarwinch.com/
- jimmydiesel
Thanks Jim
I did find the Paccar site when I was looking for info on a Gearmatic 8a winch. I looked thru it again and don’t see the Carco C12 or the Gearmatic 8a listed. I will take you advise and contact them.
440 ICD 831 Loader
440IC 831 Loader
440 ICD 831 Loader
440IC 831 Loader
My 40c has a Carco C3 that appears to be factory. However, the manual I have for it shows a Case crawler mount. Not sure how similar they are to the C12.
- jimmydiesel
Hydrogeo
The C3 and C12 are similar but different. The C3 has manual controls and the C12 has hydraulic controls
Best I can find out the C3 came first then the C12 and then the CG12 which looks like a C12 with manual controls.
440 ICD 831 Loader
440IC 831 Loader
440 ICD 831 Loader
440IC 831 Loader
