I'm looking for the newer style flywheel for a John Deere 350C/350D dozer. The manual list the part number as RE15923 (Marked R79771).
I have the original flywheel and isolator with springs (pre 706658 serial number). All the parts are worn out and the isolator no longer has the ceramic ring on it. I'm looking to convert to the newer isolator (from Lavoy) and I will need the newer style flywheel to match up with the isolator.
I'm located in Christiansburg, VA (24073).
Thanks,
Tom
Wanted: Flywheel RE15923 (Marked R79771)
1978 350CE Dozer, 6-way blade
