350c final drives
350c final drives
I have 2 good final drives off a 1977 350c crawler dozer that I parted out. Also have the steering clutch housings. Asking $500/each. These are the wet clutches off the “C”. I’m in Alaska. 907-84one-99zero4
I’d rather be lookin at it than lookin for it.
mikewilson79
Re: 350c final drives
Do you have any transmission parts for a 350C? I’m rebuilding the transmission in mine and need the pinion shaft in the transmission and the ring gear in the rear end if available.
