Main Bearing
Main Bearing
Any parts hoarders on here have a set of standard main bearings for '61 1010 gas? I am in need of the rod bearings also.
1959 440 icd 831 loader
1961 1010 dozer
1961 1010 dozer
Re: Main Bearing
I have a set of rod and main bearings, they are from my 440 ic gas, they are brand new, i ended up with 2 sets for my rebuild.
I will check tomorrow and see what size they are, maybe you could check and see if they are the same for a 440 gas, and your 1010?
Re: Main Bearing
1010 = 4 cylinder engine, 440IC = 2 cylinder engine. Different number of bearings on the cranks, different part numbers. I doubt they will match up.
Re: Main Bearing
Thanks for your concern. The search goes on.
1961 1010 dozer
1961 1010 dozer
