450d slips
450d slips
I bought this 450D and was told it was ran 3 gallons low on tranny fluid , when I changed filter up front then pulled screen filter out of side it was covered with rotten leaves. I cleaned it well and flush best I could without major disassembly. At first it pushed on a scale of 1-10 a 5 but it has slowly went to a 1 .it slips under any load . 1st thought clutches got hot from low fluid? But after seeing trash on screen I was wondering if might be another area to look or check? On flat ground blade up it will move forward and reverse in low 1 or 2 and will steer lt and rt perfectly while moving? I have service manual and technical manual also. Thanks
Re: 450d slips
Forgot to add. Called last owner crawler sat 2 years under tarp in pieces to replace frame rails
Re: 450d slips
Hello 431Dwayne,
Because of the contamination you found initially, the 5 out 10 push dwindling to 1, I would suggest another change of the filter and a cleaning of the screen. Are you in a position to change out the entire trans fluid?
Even though this is an older machine, this site would consider your machine a “late model”. This topic may get more coverage in the “late model” section. Moderators may be able to move this thread.
Also, where are you and your machine located?
Best regards,
Bruce
Best regards,
Bruce
Re: 450d slips
Welcome to the Boards.
What did you put in it for fluid/oil?
Re: 450d slips
I today pulled screen back aut and it was clean and put a new screw on filter up front. And filled with a j20 fluid. No change still slips
Re: 450d slips
Clean screen. new filter, and new J20 (C?) UTHF rules those out as the problem. Have you done all the pressure checks and adjustments for the clutch and transmission in the order given in the 450D technical manual? That would be the next step to try to identify the problem, otherwise it is just guessing.
- jimmydiesel
Re: 450d slips
Cut open the old filter and see what’s in there.
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
440 ICD 831 Loader
440IC 831 Loader
