TSX-756 Choke Valve Position
Roger440IC
Post by Roger440IC » Sun Jan 22, 2023 3:58 pm
I have a question about a 440ic carburetor that I hope someone can answer:
Should the pressure relief valve be positioned in the upper or lower half of the choke valve?
While rebuilding my tsx756 carburetor, I removed both the throttle and choke valve plates before reading SM-2024, where it recommends making note of the position of both before removal...
Thanks,
Roger
440-IC
420-U
Re: TSX-756 Choke Valve Position
Post by Lavoy » Mon Jan 23, 2023 7:05 am
If the choke is on, the flap should be able to open to let a little air in, so if it makes sense, the flap is downstream relative to airflow.
Roger440IC
Post by Roger440IC » Mon Jan 23, 2023 12:58 pm
Thanks Lavoy, that makes sense.
Should the flap be positioned above the choke shaft or below it?
Roger
440-IC
420-U
Post by Lavoy » Tue Jan 24, 2023 8:33 am
Below.
Roger440IC
Post by Roger440IC » Tue Jan 24, 2023 10:48 am
Great, thanks Lavoy
440-IC
420-U
