jimmydiesel
Post
by jimmydiesel » Sun Jan 15, 2023 10:09 pm
I am looking for 1 bucket tooth for a 440ICD 831 loader bucket.
Thanks.
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
Post
by Jim B » Mon Jan 16, 2023 4:10 pm
You may have checked already, and I don't know they are actually available, but the JD construction dealer in this area shows U10779 tooth as available to order and a price of about $60 when I log in and search that number.
jimmydiesel
Post
by jimmydiesel » Mon Jan 16, 2023 4:25 pm
Thanks Jim I had checked online with the nearest RDO farm dealer and the next nearest Pape construction dealer. And didn’t find it.
I will call the Pape dealer on the phone.
Steve
440 ICD 831 Loader
440IC 831 Loader
jimmydiesel
Post
by jimmydiesel » Mon Jan 16, 2023 4:34 pm
Problem solved. I was looking up U 10779 instead of U10779. I will order the tooth from the Pape dealer.
Thanks again Jim.
440 ICD 831 Loader
440IC 831 Loader
jimmydiesel
Post
by jimmydiesel » Mon Jan 23, 2023 10:16 pm
Well I stopped by the JD dealer today and they say not available. Darn I had high hopes. I have a few pieces of old cutting edge, I think l will try welding a piece on. If any of you come across a used tooth let me know.
Steve.
440 ICD 831 Loader
440IC 831 Loader
Post
by Jim B » Tue Jan 24, 2023 5:22 am
I would see what they might have available for similar teeth if those aren't available. CAT, Case. or other equipment dealer might have something that will fit. ESCO and Hensley are a couple major aftermarket players as well. You might not find a direct bolt up match, you might just need to drill different hole or two. You could look at weld on shanks since you are thinking of welding pieces of cutting edge to it. Many new styles the shanks are fixed (welded or bolted on) and actual tooth/tip is replaceable.
jimmydiesel
Post
by jimmydiesel » Tue Jan 24, 2023 12:36 pm
Thanks Jim
That is what the JD parts man suggested also.
He also took me in the back and showed me all the teeth options that they stock. I did some looking online and see some that are similar in design. So lots of options.
The 440IC 831 has a big hole in the side of the block so it will be awhile before it’s running. I have an extra 2-53 and most of all the parts to change it over.
Steve
440 ICD 831 Loader
440IC 831 Loader
chrisgo541
Post
by chrisgo541 » Wed May 15, 2024 7:09 pm
Good evening, Are you still looking for this bucket tooth U10779 ? I have 2 very nice used ones. Just saw your post. Thanks Chris
jimmydiesel
Post
by jimmydiesel » Thu May 16, 2024 9:52 pm
Yes I am still looking. I found some other bolt on teeth that can be made to work if I have to but still looking for a matching tooth.
440 ICD 831 Loader
440IC 831 Loader
chrisgo541
Post
by chrisgo541 » Fri May 17, 2024 6:32 am
Fell free to call me 541-420-8899
