Need help out in the woods, lol !
pearljam724
- 430 crawler
I’m not near my manual. How many gallons of hydraulic fluid for transmission ? 65 - 450 loader
- jimmydiesel
Re: Need help out in the woods, lol !
13 gallons. For the hydraulics 8 gallons for the transmission
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
440 ICD 831 Loader
440IC 831 Loader
pearljam724
- 430 crawler
Thank you, I just found in my manual it’s 8 gallons. There is separate oil for reverse ? I have a second question. I sprung a leak on what appears to be the hose attached to the filter. It has no fittings, it’s just hose clamped on. And that doesn’t appear to be rigged up incorrectly. Can I take an ordinary hydraulic hose and cut it with a 4 inch grinder ? It is braided just like a hydraulic hose. Can I cut a hydraulic hose and just clamp it on like the other ? The hose that is leaking runs under the rad and I assume it runs along the rail beside the right side of engine. I see three bolts up near the front of the machine that holds this plate on. Is this plate easily removable and is it fairly easy to access the other end of this hose one I do ?
- jimmydiesel
I had the wrong info to start with on a reverser. Got it fixed about the same time you posted.
440 ICD 831 Loader
440IC 831 Loader
440 ICD 831 Loader
440IC 831 Loader
pearljam724
- 430 crawler
I know buddy. Thank you, for your willingness to help. I appreciate it.
