Log arch/
Jaybird
Log arch/
Post by Jaybird » Sun Dec 18, 2022 6:34 pm
Does anyone know if a log arch off a 350 or a 1010 will fit a 440 ? I would also like to know if a reverser from an early model 440 will fit on my 1960 430 wheel tractor? Thanks in advance
Re: Log arch/
Post by Lavoy » Mon Dec 19, 2022 8:55 am
Definitely not from 350, 1010 possibly depends on winch.
Yes, you can remove the reverser internals and install in your center section.
Jaybird
Re: Log arch/
Post by Jaybird » Mon Dec 19, 2022 9:14 pm
Does the whole housing from the 440 fit the 430 wheel tractor? How will this effect the clutch? Or will it?
Re: Log arch/
Post by Lavoy » Tue Dec 20, 2022 9:01 am
It will depending on the 440 serial number, but you should take it apart and check it out before installation anyway.
