350c thrown track
Gwilkrrs
350c thrown track
Post by Gwilkrrs » Wed Nov 16, 2022 6:35 pm
So I threw the other track now. I was able to pump some grease in the adjuster to extend it some and break the stuck piston and then collapse the tensioner piston. Then it took me a couple days to get the track back on the sprocket- I then put the zero fitting and bolt in and went to pump the piston out to tighten the track- grease came out the bottom of the adjuster instead of filling it and extending it——-
I just remembered it needed a bb at the bottom of the bolt and have ordered a new one- hopefully that is the issue?
77 Ford
Re: 350c thrown track
Post by 77 Ford » Thu Nov 17, 2022 10:48 am
Probably so, if it's an original style adjuster, remember you do not need to take the bolt all the way out just loosen it till grease starts to flow out the hole. Then you are less likely to loose the BB.
JD- 450C track loader
Serial #208336T
Gwilkrrs
Post by Gwilkrrs » Sat Nov 19, 2022 5:32 am
I guess a loose bolt would allow the grease to release- but when dealing with a stuck stiff cylinder I wanted 0 restrictions as I was already fighting a losing battle-
Good to know for future tho-
BB comes in a couple days so hopefully that solves it
