JD350 (straight) Lift Pump Pressure
Rainfly
Post by Rainfly » Thu Oct 27, 2022 5:35 pm
Howdy,
Quick question. What would be an acceptable fuel pressure for an electric fuel lift pump? Currently showing 5psi after the lift pump and before the filters.
TIA
Re: JD350 (straight) Lift Pump Pressure
Post by Jim B » Thu Oct 27, 2022 6:11 pm
Welcome to the Board.
Don't be surprised if you find your post on the Late Models Board when you look for it. The 350 a models built after their production started are covered on that board. A moderator will likely move it over there when they see it.
The specs for the pumps used on a 450B (many others including the 350 use the same transfer pump) are: 3-1/2 to 4-1/2 psi at 16 inches above the pump outlet at 1800 camshaft rpm. The flow is 2 quarts per minute (30 gallons per hour) to 3 quarts per minute (45 gallons per hour) at 2 psi at 1600 camshaft rpm.
Rainfly
Post by Rainfly » Thu Oct 27, 2022 7:37 pm
Perfect. Thanks
